Courtesy Lights not working!!
I have a crew cab 2006 F-250. Both the front and rear overhead ceiling Courtesy Lights fail to come on when the doors are opened.. The map lights work fine when their switches are turned on. I have replaced both courtesy light center light bulbs with no luck.. I must assume that the door switches (although I cannot find them) are working as I get a door ajar warning when that condition exists.. Any ideas and where are the door switches located? Help please..
Fuse F35 was blown... never thought that map lights / courtesy light would have separate fuses.. replaced fuse, blew again... I then totally removed the rear courtesy light fixture and unplugged it.. replaced fuse and all is good with front fixture... underside of rear fixture at the courtesy light bulb holder is corroded and looks like someone did something to it in the past...will check for shorts and repair or replace it next week.. thanks again for your help...
