F-250/F-350 Factory 4'' Block Question
Can someone on here with an F-250/F-350 post a picture of the factory 4'' blocks? I am curious to see if they have the bump stops integrated into them, as the 2'' factory 97-03 F-150 blocks. Also, what is the spring/perch width on the F-250/F-350 Superduties?
What I am wondering is if I could possibly swap in a set of factory 4'' Superduty blocks under my 03 F-150 with the 2.5'' wide leaves and 9.75 rear end. I do not want to buy a 4'' block from another source because aftermarket ones do not have the bump stops integrated into them as the factory ford ones do, and I do not want to stack blocks in order to reach a higher height. I am already running a set of heavy duty atlas leaves, so updating the stock F-150 leaves is out of the question as well. Thanks for y'alls help, and sorry for the long post, lol.
