2003 F350 7.3L tow rating
Technically, no.
US DOT regulations: Part §658.17 - Weight. The maximum gross weight upon any one axle, including any one axle of a group of axles, or a vehicle is 20,000 pounds.
All F250/350's (listed in the 7.3L Supplement), regardless of cab/bed/axle ratio/rear wheel configurations, are rated at a 20,000 lb max. GCWR.
Technically, no.
When the F250's (in this yr range) are listed at the DOT's max GCWR, then obviously, the F350's (regardless of SRW or DWR) are going to have a higher capacity.....but logic and DOT don't always mix, especially when they put you on the scales.
