Biodiesel & Ford's response to my ?
I thought you guys might find this info. useful. I recently wrote Ford regarding the issue of using Biodiesel in my rig. (04 F-250 6.0 PSD.) And this is their response:
Thank you for contacting the Ford Motor Company Customer Relationship Center regarding the use of biodiesel fuel. Fuels containing no more than 5% biodiesel may be used in Ford diesel powered vehicles. There are still some unresolved technical concerns with the use of biodiesel at concentration greater than 5%. Some of the concerns are as follows: - Special care is required at low temperatures to avoid an excessive rise in viscosity and loss of fluidity - Storage is a problem due to higher then normal risk of microbial contamination due to water absorption, as well as a higher rate of oxidation stability which creates insoluble gums and sediment deposits - As it is hygroscopic, the fuel tends to have increased water content, which increases the risk of corrosion - Biodiesel tends to cause higher engine deposit formations - The methyl esters in biodiesel fuel may attack the seals and composite materials used in vehicle fuel systems - It may attack certain metals such as zinc, copper based alloys, cast iron, tin, lead, cobalt, and manganese - It is an effective solvent, and can act as a paint stripper - It tends to loosen deposits in the bottom of fuel tanks of vehicles previously run on mineral diesel. Should you require additional information about this matter, please contact the service department at your local Ford dealership. To locate a Ford or Lincoln-Mercury dealership, please visit www.genuineflmservice.com. We consider the satisfaction of our customers one of our most important objectives. If you have any other inquiries or concerns, please feel free to contact us and we will be happy to address them for you. Sincerely, Maisha Customer Relationship Center Ford Motor Company |
Yep they are dead on with their explanations. It can be done, but if not done right it can cause alot of problems.
With all the talk about Biodiesel, I wanted an official answer from Ford. There is no way I would put the stuff in MY engine, without an officail yay or nay from Ford!!!!
| All times are GMT -4. The time now is 03:43 PM. |
