Expedition / Navigator
Window Replacement
Old Dec 7, 2004 | 05:40 PM
Jerry Smith's Avatar
Question Window Replacement
The driver side window came loose from the clips on the bar that raises and lowers the window. I pushed it back into the clips but it would not stay in place. I tried epoxy glue but that did not work either. Does anyone know what I need to do? Maybe a more flexible adhesive?
Old Dec 12, 2004 | 01:08 PM
MaxTorque02's Avatar
Re: Window Replacement
On my Navigator, it happened to my passenger window. I just used clear adhesive silicone. The stuff that is used for aquariums. It's important to make sure you get the clips in the right place to ensure the window travels up the tracks properly, otherwise it will bind and cause the clips and window to seperate again. Also make sure to clean the window and the clips of any of the old adhesive to ensure the best grip and to let it set up at least 24 hours before using it. Good luck.
