F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Expedition / Navigator (https://www.f150online.com/forums/expedition-navigator-60/)
-   -   Well it wasn't my trans..... (https://www.f150online.com/forums/expedition-navigator/133611-well-wasnt-my-trans.html)
WALL96COBRA Oct 26, 2003 11:27 AM
I had posted a while back that I thought my torque converter was going bad but it turned out to be a misfire and not the TC slipping so I changed my coil boots and my spark plugs out and the problem is GONE!!!:banana: It took me almost 2 hours and some scraped up arms but it was alot easier than replacing a torque converter. I read in another post in the engine section and talked to a ford mechanic and that's where I found that it was a common problem for the coil boots to get small cracks in them and they start to arc through the cracks and ground out causing a mis at certain rpms. I wanted to post this just incase anyone else has this problem and assumes it is the torque converter (like I did).
