Advice on 1999 Exhaust Setup
Hey guys, I am fairly new here and have been considering doing a new exhaust setup on my 1999 4.6L F-150. I had in mind of doing longtubes, into high flow cats and than true duals into an x-pipe, siso mufflers and out... However, talking to my muffler shop here in Boulder CO, I was told that I wouldn't pass emissions if I changed to high flow cats. The 1999 F-150s had 4 cats on them, essentially a pre-cat and a cat for each header. I am wondering why I can't replace those cats (both the pre-cat and cat per header) with a single EPA compliant high flow cat such as this on:
My plan for this system is to get a performance increase while also making the truck a bit louder, am I going down the right track?
Thanks in advance for your guy's help!
https://www.amazon.com/Universal-Catalytic-Converter-410250-Stainless/dp/B01N41NJIP/ref=sr_1_2?ie=UTF8&qid=1493680411&sr=8-2&keywords=high+flow+catalytic+converter
? I would then run the pipes downstream of the cats into the x-pipe and so on. The shop here just recommended to take out the Y-pipe and run the pipes into a DIDO muffler to act as an x-pipe and then run the pipes out. What option should I go with?My plan for this system is to get a performance increase while also making the truck a bit louder, am I going down the right track?
Headers and high flows really aren't worth the money, you really won't get better performance without more mods.
Cutting the Y-pipe and getting a DI/DO with internal X-pipe is the most economical way to get a slight improvement and better sound. Your muffler shop is on the right track. Then do a Gotts mod to the intake air box. A programmer with custom tunes will give you a lot more performance increase than any exhaust or intake mods.
