Old 04-13-2015, 02:23 PM
How-Tos on this Topic
Last edit by: IB Advertising
The Exhaust Guide
Find out the do’s and don’ts for you next exhaust.
Topics Include:
• Configurations
• Mufflers
• Cats and Catless
• Tips and Exits
• Pip material and Bends
• Recommended Items for Purchase
Read full discussion for further information
Print Wikipost
THE Exhaust Guide
Old 09-16-2010, 10:05 PM
MGDfan's Avatar
Originally Posted by jbrew
This is something that's been needed for along time. It's good as well. Yea, if you can just keep adding info/editing your first post (keep it all in one place), - maybe to elaborate or just add more info from time to time, - this could be the best "sticky" on the site, IMO.
Yah - it'll be exhausting work fer the youngin' but worth it.
Help to keep da bum bizzy & outta trouble
EDIT - HEGO = http://fordfuelinjection.com/?p=31
MGD
The following users liked this post:
Old 09-16-2010, 10:12 PM
4.6 Punisher's Avatar
MGD
I really don't have any knowledge in O2 sensor field. If you can write up a section on it, I would gladly put it in the guide. Of course credit will be given.
Old 09-16-2010, 10:58 PM
jbrew's Avatar
You touched on it here a bit -
By tuning the length of the primary tubes, usually by means of resonance tuning, the rarefaction pulse can be timed to coincide with the exact moment valve overlap occurs. Typically, long primary tubes resonate at a lower engine speed than short primary tubes.
O2's run cooler further downstream on a LT install. Leans AF's, but only @ WOT I believe. Temp vars are reprogrammed via tuner. That's what is meant by tuning length.
Old 09-16-2010, 11:23 PM
Jared Lutes's Avatar
Great work, I know I deff. would have used this. I am sure it will be used by many others on the site. Thank you for your contrabution.
Old 09-16-2010, 11:28 PM
Msbowhunter's Avatar
Thanks for the info. This may help me a lot.
Old 09-16-2010, 11:35 PM
rednoved's Avatar
Nice guide. Did you obtain permission to use all the photographs though? Since this thread is now under the spotlight, legal actions could come into play?
Old 09-16-2010, 11:46 PM
Another one.......
Quality grades and types of tubing.
Old 09-17-2010, 03:20 AM
jbrew's Avatar
I don't see anything wrong with the pics or statements. No misrepresentation. It's free advertising if anything (as far as pics go).
He might just get a metal.
Old 09-17-2010, 06:53 AM
MGDfan's Avatar
'Brew - transport delay - it's function of distance (delta thereof from OEM location), not temperature: https://www.f150online.com/forums/2459171-post11.html
On that note - perhaps a reference to which longtubes require correction and which do not (a tuning vendor will know this, like Mike above).
MGD
Old 09-17-2010, 09:35 AM
Also we should make an intake guide... don't wanna leave out the Sphinkter!!
Old 09-17-2010, 09:49 AM
and you forgot the H-pipe is for low to mid range performacne and the X-pipe is for mid to higher rpm performance
Old 09-17-2010, 09:54 AM
MGDfan's Avatar
MGD
Old 09-17-2010, 09:59 AM
jbrew's Avatar
MGD
Yea, I thought delay only had to be messed with if you were spitten 133/153 DTC's, and after an install (delay increase). That doesn't happen to often.
I stand corrected then..- Dammit, that's twice this week. Can't argue with Mike.
Old 09-17-2010, 10:11 AM
MGDfan's Avatar
Nah - don't sweat it - that's what, 2 out of 12,000 good ones? I'd say yer doin' just fine
Here - we need ya: post # 38 ==> https://www.f150online.com/forums/ex...her-stuff.html
Sorry - I don't got a 'Jbrew' BatSignal
MGD
Old 09-17-2010, 10:25 AM
jbrew's Avatar
MGD
- Oh brother, - I can't help him. He has plugs blowing out from a lean condition? - I have nothing positive to contribute, at the moment. Unless ? Unless your referring to the ladder ?
Quick Reply: THE Exhaust Guide
