Last edit by: IB Advertising
The Exhaust Guide
Find out the do’s and don’ts for you next exhaust.
Topics Include:
• Configurations
• Mufflers
• Cats and Catless
• Tips and Exits
• Pip material and Bends
• Recommended Items for Purchase
Read full discussion for further information
Topics Include:
• Configurations
• Mufflers
• Cats and Catless
• Tips and Exits
THE Exhaust Guide
#77
ON a true dual setup, I have reduced greatly the non symetrical issue.
I criss cross my tailpipes coming out of the mufflers so I am running the passenger bank exhaust out of the drivers side and vice versa. What that does, is equals the exhaust more closely instead of making the drivers side bank go across to the pass frame rail and then back across to the drivers rear and out. That 2.5ft of tubing you loose up front, you get back after the muffler. Works well.
That makes both sides very close to equal. I add an H pipe for good measure and get a really nice sounding exhaust system. Use Dynomax Super turbos with flow through tubes in 2.5 inch diameter and some echo tubes and it sounds mellow, but good.
Thats the only way I know to equal the pipes up on a true dual system. Have done it on 1 Ford and 4 chevy's. Can't say it helped the power all that much. I didn't dyno it.
I have picture, but don't know how to post them.
#79
What it is adding is balance to the system. You are gaining to pipes that are much closer to equal length than running the drivers side out the drivers side. In that configuration, that pipe is about 3 to 4ft longer than the pass side. by switching the tailpipes at the mufflers, you make the pass side exit at the drivers side.
Obviously this only works if you run your tail pipes out the back, or at angles on both corners. If you have both coming out one side, then this is of no benifit
#80
That's what the cross over is for, equalizing the pressure between the pipes. I'm just guesstimating, but I would say there is a 1-2 HP difference at the most. I think bend quality and pipe size would affect it more than criss-crossing the pipes. But I still want to see how you did it, for future reference.
#81
It takes the dependence off of the cross over. IF there is enough difference in resistance between the two sides, it is going to force more exhaust through the crossover. This way, it balances the system much closer and the cross over just picks up the small differences, and not huge ones, because there won't be any.
Also, it is very easy to do. the mufflers are right together, might be a inch more pipe used on each one. I have never dynoed it before and after, but I figure the more closely I can make the two pipes equal, the better scavenging I can get.
#83
Gentlemen,
At the risk of hijacking this thread from the current discussion on piping configuration, I was wondering if anyone could comment on material type: aluminized, T409, and T304 stainless steel. I plan on keeping my 2010 for at least a dozen years, I live in a wet climate, and I don't want to be replacing the exhaust if I don't have to.
Aluminized stainless steel is not in the running but I was wondering if anyone had any opinions as to whether is it worth it to go with the higher nickel and chromium content of T304 stainless steel or settle for T409.
Thanks in advance.
Thanks in advance.
#84
#86
#89
on
Gentlemen,
Thanks in advance.
Thanks in advance.
