BBK headers don't fit
What do you do when there's intereference between the #3 pipe and upper control arm bracket? It needs about 1/4" - 1/2" to prevent from vibrating a hole in the pipe. This is on the passenger side btw.
Well, if they weren't so "purty" - I might recommend hammer mods :eek:- but
I wouldn't want to see them dented - and they're not even mine !! They are definitely for your specific application? If so, I'd have to consider sending them back. |
Yep, numbers match.
I was thinking of using a c-clamp to push in the one side slightly. 1/4" might do it. but I'm wondering what that would do to the ceramic coating. I'm running out of time so I have to make do. |
Have you called the manufacturer?
you may be able to loosen the engine mount bolts and reposition the engine over 1/4 inch, not too hard
I will say this, over the 4 sets of BBK headers I have owned every single set had to be massaged with a few blows from a BFH. They have horrid QA.
| All times are GMT -4. The time now is 02:25 AM. |
