F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Exhaust & Intake Systems (https://www.f150online.com/forums/exhaust-intake-systems-27/)
-   -   Q's about AF1 and upcoming inspection (https://www.f150online.com/forums/exhaust-intake-systems/296118-qs-about-af1-upcoming-inspection.html)
TexEdition Aug 5, 2007 03:00 AM
I need to take the truck in for inspection next week, 15K service, both will be done at the dealer.
The only mods on my truck are a borla cat-back (no worries there), and a 3" AF1 cai. Both of these have been added since my last trip to the dealer.
I'm in Austin, Tx.. Travis county. They've just started doing emissions testing in the past 2 years. This is the first time since then that I've needed to renew inspection.
1) will my truck pass inspection with the AF1? There's no "CARB" sticker for it, isn't that a California standard? Would it apply to me here?
2) My dealership has been nothing but great with me so far, but what are the odds of them seeing the AF1 and gettin' weird about it?
I can put the stock intake back on if needed, not a problem.. but what are y'alls opinions on this? Do I need to put the stock back on?
Thanks in advance!! :beers:
SCOTTE`screw Aug 5, 2007 11:14 AM
you should have gotten a sticker when you purchased it....im sure if you print out something stating that it is CARB legal you wont get to much grief...
Airforce One Performance Intakes are designed from the ground up for absolute performance, quality and longevity. These systems use aviation grade stainless steel polished to a mirror finish that will never rust or corrode regardless of the climate the system is exposed to. Custom designed and molded Hi-Temp stabilized composite adapter boots, couplings and MAS airflow venturi adapters are used. The venturi adapter generates a high vacuum in the filter enabling the filter to draw a higher volume of air while naturally lowering the ambient incoming air temperature by several degrees, eliminating the need to enclose the filter in a box and substantially increasing horsepower. The Power Stack Filters are sized to each system and carry a lifetime warranty.
A Complete System From The Throttle Body Out!
Polished 304 Stainless Steel!
Features VFA Venturi Filter Adapter!
Includes Power Flow Filter!
Easy Bolt-On Installation!
HP & Torque 18 HP/29 ft/lb Torque
Installation Designed to Replace the Restrictive Factory Air Filter Housing. This is a BOLT-ON Kit. Installation Normally Takes 20-30 Minutes and All the Necessary Hardware is Included. Only Regular Hand Tools Required. Comes With Instructions.
Tech Notes 50 State Smog Legal <<<<:thumbsup:
gonefishin10 Aug 6, 2007 08:04 PM
the sheet that came with my AF1 says that it is NOT carb legal...it says that it is in testing in order to become carb legal.
which sucks cuz here in colorado we have emission testing...i haven't put it on yet because i will need to renew my registration soon, which is when i will need to get the vehicle tested.
05RedFX4 Aug 6, 2007 08:59 PM
C.A.R.B. is a California standard, you only need to worry about a carb cert if you live out there in la-la land.
BTW carb stands for California Air Research Board
gonefishin10 Aug 6, 2007 10:40 PM
our emission laws are are pretty strict but probally not quite as strict as CA. i am not going to put it on and fail, then pay another 30bucks to have it retested...back when i had my ranger, i failed an emission test because of my gas cap.
05supercrew Aug 7, 2007 08:48 AM
Most states wont bother you. I now NY inspection, plugs into your computer and if there isnt a service engine light you wont have a problem. 1995 and older still go on a dyno here to check emmisions. It depends also on the visual inspections and here there isnt a problem.
TexEdition Aug 7, 2007 08:53 PM
Well, I'm on vacation this week, had nothing else to do this afternoon so I went ahead and put the stock intake back on.. hey, it was something to do.. lol
The growl is gone, the git-up-and-go is gone.. :(
Figured it's an opportunity to clean the AF1 filter, so I'm doing that.
That AF1 is sure as hell going back on as soon as I get back from the dealer tomorrow!
Before:
https://www.f150online.com/galleries...306-187547.jpg
After:
https://www.f150online.com/galleries...306-198776.jpg
waaaaaaahh!!
Yeah it's dirty, I know it's dirty ok! :beers:
05supercrew Aug 8, 2007 08:24 AM
Big difference.
Huitt24 Aug 8, 2007 02:54 PM
In Texas for our year trucks all they do for the emissions test is hook up to the computer and make sure no codes have been thrown. It will pass the visuall test because it is not a thermostatic type air cleaner. Mine pasted just fine when I had my AF1 on there and a set of long tube headers and true dual exhaust.
TexEdition Aug 9, 2007 11:15 PM
Huitt, did you take in to the dealer? Mine's never thrown any codes either, was just mainly worried about the dealer givin' me a hard time warranty-wise - still have 3 years left under warranty. Btw, got the inspection and 15k service today, almost $250 :eek:
LOL, when I bought the truck inspections were still like $18.. it's been 2 years, I didn't realize it was 30 bucks now!\
:beers:
PhqChevys Aug 13, 2007 03:56 AM
:beers:
You don't even want to know what it cost in Arizona... I bought my truck there and they charged me $572.83 JUST FOR THE REGISTRATION for 1 year!!! I have since then moved to Texas and my registration is about $72 per year. That's insane that Arizona can bend people over like that!!!
TexEdition Aug 14, 2007 12:06 AM
Holy crap!! Do they tell ya the breakdown as far as where all that money goes? Here in Tx it's like 50% for the registration itself and 25% for "bridge maintenance fees" (depending on the county), and the rest to the DPS retirement fund.
Screw-Me-05 Aug 14, 2007 07:17 PM
Move to florida...... no inspections at all but just about everyone here has a brand new vehicle including me woo hoo but in new york where im from holy moly was it ridiculious but if you knew the inspector and waved some green you were fine.:rocker:
