3rd brake light blinks
Had my shell installed yesterday now 3rd brake light blinks with turn signal on shell anybody know were I can hook up to.
Wiring diagram show BRAKE GRN (+) SWITCH ABOVE BRAKE PEDAL there has to be some place else
Thanks Dogface
Thanks Dogface
For your Info
You will find a GREEN wire in the harness by your trailer hitch that is folded and taped over, and not connected to anything.
The wire connects the brake light switch to the brake controller unit.
I have the trailer tow package and the wire is there. I don't know if its there on the connection for the flat 4.
If you follow the hitch plug wiring back about 18 inches, you will see another set of covered wires that T off into another direction, behind the driver’s side rear wheel. It was in there.
I found the green wire in the wire bundle going to the driver’s side tail light. It was sticking out of the plastic wire cover and taped back to the cover. (At the T)
Your service rep can probably tell you exactly where it is.
Dogface
Dogface
