Question on New Gauge Installation
I just purchased a new set of Autometer Gauges (Water Temp and Oil Presure) and want to install them in my 2001 f-150 HD SC. I want my OEM gauges in the dash cluster to also keep working in conjunction with my new gauges. any suggestions?
Please help Thanks, Bones. |
The gauges are electrical, so all you need to do is tap in to the wires going to the factory gauges, then hook up to your new ones. You may want to look at a wiring diagram and make sure you tap in to the right wire.
Just take your dash apart (he he) and then run your wires. Sounds simple, and it is, but just takes some time to get the dash apart, and back in. |
