2009 Platinum DRL
I have a Canadian spec truck with DRL's. The l/h drl has quit working and I am trying to find the relays and resistor that control them. I have looked at every location pointed out on the web and cannot find them. The owners manual does not list anything for the DRL's or the lowbeams other than the fuses in the fuse block inside the truck. I have checked these and they are ok.
Thanks |
IIRC the resistor is under the cover in the top center of the dash. I'm not sure about the relay. There was a thread on here years ago about how to add the resister to American trucks in order to add the drl feature like the Canadian trucks have.
Thanks Joe,
Normally, (from what I've seen on the web) there is a cover you can remove if the relay is under the dash cap, but mine is one complete piece all the way across. That doesn't mean it isn't there of course. That would be my luck. haha Tom (Sabre) |
