Headlamps staying on 2006
My headlamps stay on (sometimes and drain the battery).
DRL(daytime running lights) , AutoLamp equipped 2006 SCREW
I had all components of the DRL(two relays and resistor) removed and drove around still the lights stayed on.
Even removed the HeadLamp Switch and the PhotoDiodes/Led module on the dash..no joy.
Then I found a thread on a bad "fusion" splice in the wiring harness and I fixed it after tearing the back seat out.
https://www.f150online.com/forums/el...ical-help.html
Appeared the fault was fixed and I drove around with all the stuff (BCM & wire harness) still exposed for a week just in case the fault reappeared.
Then I put the BCM (Body Control Module) back on its mounting post and reassembled the back seat and associated plastic.
All was well.
Then I put the DRL components back in.
Then I went for a spin at night time with Light Switch on Auto....
Then I parked her and turned off ignition....the dang lights wouldn't turn off..again
Any ideas?
Park Micro-switch in Steering Column?
Wires in the door conduit open?
BCM is hung up?
I have the schematic and I can see how 12Volts can be sensed from the BCM at the headlamps independent of the other parts of the circuit.
Much Obliged
Doog
All was well.
Any ideas?
BCM is hung up?
Much Obliged
Doog
Anyone?
SSCULLY?
I found a thread:
https://www.f150online.com/forums/el...t-problem.html
Following
Doog
SSCULLY?
I found a thread:
Following
Doog
