Need help
Hey guys i have a odd issue .. I've thrown multiple parts at it all fuses are good too . I have a 1999 F150 V6 2WD . Right after I got it the auto trans went to **** I replaced it with a 5m/t . Now I have no speedo or odometer.. after 2-3 miles the odo shows dashes . The Vss at the rear of the gear box is good and sends signal to the PCM . Bu still nothing , I've changed the trans harness and the sensor on the rear as well . When I swapped everything I had a 01 PCM programmed with the ford interface by a friends at a local dealer because if the ****ty ass pats system . Everything is fine but the speed and odo my brain it out of ideas and google only seems to have the flickering odo screen repair and that is not a issue I have
