Intermittent problems with dome/map lights
Sometimes they work when you open the door or hit the fob, sometimes they don't. Now today, the front won't work no matter what you do, including clicking for map light. The doesn't work with door open, but will if you turn it to the permanent on position.
Help! |
No one?! I had them going today with the doors and fob just by chance. Now nothing; no cargo or interior domes. All new bulbs. I have tried fuses. What relay to check? 2006 f150 lariat.
I know you have probably identified your truck in other threads, but you need to do that in this thread too.
Sorry about that.
The dome light will stay on if you turn the wheel for the instrument panel all the way to the brightest setting and it clicks. Just turn it back till it clicks and the dome light will turn off
Originally Posted by rothd51
(Post 5157381)
I had a similar problem where my dome lights weren't working either. Mine seemed to be connected to having water down by the wires on the passenger side floorboards. Once that was drained and dry everything worked as normal.
Both sides of mine appear to be and have always been water free. Guess next step is to pull door sills off and check
