no brake tail or turn lights on 98 F-150
The plug in for the trailer lights got torn off now I have no lights
Where did your son cut the wires off at ?
Does the CHMSL ( Center high Mount Stop Lamp ) still work ? Did you check the fuse for the stop lamps, while the fuse is installed, from a known good ground to each pin on the back of the fuse ? |
Someone who knows what they're doing will need to rewire it.
