door/window controls
2007 f150 king ranch. I can control the windows and locks from the driver's side door but nowhere else. I checked the safety locks and they are not on. any ideas?
That is a strange one.
I'd say pull the switch from one of the others ( i.e. front pass door ) and test to see if you have + VDC on the yellow w/ light green stripe wire. This is the output of the window lock switch ( turns power on and off to the other windows ). If you do not have + VDC on the yellow w/ light green stripe wire with the lock off, I would take a SWAG it is the yellow w/ light green stripe wire broken in the boot from the door to the a pillar. Could be closer to the switch or the switch itself, but I would guess it is in the rubber boot. https://www.f150online.com/forums/me...er-windows.jpg That is my 1st place to start looking. |
thanks for the info. I will give that a try
