F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Electrical Systems (https://www.f150online.com/forums/electrical-systems-67/)
-   -   speedometer won't work at all. (https://www.f150online.com/forums/electrical-systems/459250-speedometer-wont-work-all.html)
ladyhawkjj Oct 24, 2011 06:29 PM
This is a 98 F150 extended cab. The speedometer, odometer and cruise control suddenly quite working. Is there a sensor, fuse or cable that could be the culprit? It has just over 100000 miles on it.
projectSHO89 Oct 24, 2011 07:02 PM
Yes, there probably is, but you'll need to provide more specifics about your vehicle.....
ladyhawkjj Oct 24, 2011 07:08 PM
speedometer
What do you need to know?
ladyhawkjj Oct 24, 2011 07:20 PM
It's an eight cylinder 4.6 L , automatic
SSCULLY Oct 24, 2011 07:39 PM
did you have recall 05S28. Description: Speed Control Deactivation Switch completed ( think your MY truck was on the list ) ?
The speedo is a manual item with a cable if I am not mistaken ( gear driven item that is usually changed when larger tires are installed ), so it could be you have 2 different problems at the same time.
