Trying to wire switches to turn of and on when truck does
i have a 08 Lariat.. can any body give me a hand i know how to wire the switches and all i just need to know what wire im splicing too that will run the hot to a small fuse panel and from there im golden.. pics would be awesome if somone has done something like this
If you are powering a fuse panel, you will want to use a circuit to trigger a relay that is attached to the battery.
The easy way is to use an Add A Fuse in one of the slots depending if you want hot in run only, or hot in run / accy or hot in run / Accy delay. Did I read correctly that you want to run a fuse panel off this & which position do you want it to be hot in ? |
You can't power a fuse panel directly from an existing switched circuit. You can tap existing circuits to trigger relays which then power fuses/devices/switches. The correct wire to tap in each case depends on exactly how you want the new device to behave.
Sorry I was not so clear on what I was trying to do im adding 4 rocker switches to power accessories like they have in the superdutys. All the switches go to a 6 fuse fuse panel I got at Autozone the panel has one hot in that right now comes from the battery. What im trying to achieve it have it set up were if I forget to shut them off when the truck is off and vise versa
so the switches are controlling relays of their own, so the load per switch is > 0.2 A, Correct ? ( i.e. nothing is run directly off a switch ).
Do you want hot in run only, or hot in run / accy or hot in run / Accy delay ? All 3 of these qualify as off when the truck is off. |
Each fuse should run to its own relay (pin 30 if using Bosch/ISO relays), then out (from 87) to each device. Generally, you'll ground pin 86 & run 85 to a switch & then to the factory circuit, but that arrangement can be adjusted to get different behaviors.
https://www.supermotors.net/getfile/...htersocket.jpg |
