fuel guage
I started up my truck the other morning and noticed my fuel gauge on empty. As i was driving to the gas station the low fuel light came on. I pumped about 5 gallons in and the punp shut off. I tried putting in more gas and it was full. The fuel guage has read empty since. Any ideas about this would be appreciated. I have an '06 F-150 screw KR. Thanks.
Where do you fuel at ?
There is a condition with high sulfur content fuel that causes problems with the fuel gauge, TSB 08-2-9. TSB 08-2-9 02/04/08 ERRATIC FUEL GAUGE OPERATION - MIL ON - DTCS P0460/P0463 OR INSTRUMENT CLUSTER MODULE DTC B1201 - VEHICLES BUILT BEFORE 12/3/2007 FORD: 2004-2008 F-150 LINCOLN: 2006-2008 Mark LT ISSUE Some 2004-2008 F-150 and 2006-2008 Mark LT vehicles, built before 12/3/2007, may exhibit erratic fuel gauge operation or illuminated malfunction indicator lamp (MIL) with diagnostic trouble codes (DTCs) P0460 or P0463, and/or Instrument Cluster Module DTC B1201. This may be caused by sulphur contamination in the fuel causing an open or high resistance in the fuel level sender. ACTION Follow the Service Procedure steps to correct the condition. SERVICE PROCEDURE Install a new fuel level sender following the service procedure instruction sheet provided in the fuel sender kit. WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part. OPERATION DESCRIPTION TIME 080209A 2004-2008 F-150, 1.9 Hrs. 2006-2008 Mark LT: Install New Fuel Level Sender, Includes Time To Remove And Install Fuel Tank (Do Not Use With 9002A, 9002A4, 9002A6) DEALER CODING CONDITION BASIC PART NO. CODE 9A299 42 |
I assume this is in the Tank?
I assume if you drop the tank to do this, you should replace fuel pump while you are there? Does this permanently fix this or once this one gets coated over time it will do again? Thanks |
