F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Electrical Systems (https://www.f150online.com/forums/electrical-systems-67/)
-   -   I bought DRL kit...can't find plug for resistor under the hood. (https://www.f150online.com/forums/electrical-systems/42376-i-bought-drl-kit-cant-find-plug-resistor-under-hood.html)
Newbie46 May 17, 2001 11:15 PM
I even removed my driver's side headlight and looked there, under, and even behind the bumper and no luck. It was easier to locate in my friend's Supercrew. But mine is the Supercab and no driving light. Help!
2000 EXPEDITION 4.6 3.31 Rear, AIRAID Fipk with Poweraid Spacer, UltraFlow muffler, 82 mm Mass Air Flow Sensor housing w/ stock sensor, 6.8 inch TV with tuner/VCP, Full alarm and Auto-Start, Daytime Running Lights
New Addition:
2001 F150 SUPERCAB 5.4L 3.55 LS, Airaid FIPK, 82 mm MAF sensor billet aluminum housing w/ stock sensor, Full alarm and auto-start, 50 series 3 chamber 3inch in/out Deltaflow Flowmaster
Swept Side style, Beltech 2 inch rear shackles, SUPERCHIP, billet grille, Lariat wheels and tires (275/60/17), Billet antenna by TRENDZ.
COMING SOON:
pulleys, remove cats, 2 inch drop all around.
derBierliebhabe Feb 14, 2003 07:54 PM
Did you ever find out how to hook up the resistor or where the plug for it is located? I am in the same boat as you. I saw two wires that onnect to a jumper bolted onto the frame behind the left headlight, but there is not a plug on the end that would match up to the resistor. Could these wires be the connection point but without a plug? I need to check the wiring diagrams. :bows:
bdmofo Feb 15, 2003 01:50 PM
I just did it on my 02 and the plug is right there. It plugs into a dummy plastic recepter.
Check out this site. It must be there, because Ford sells you truck in Canada and it's manditory to have, and i know they wouldn't use a different wiring harness in the US, since the truck is all one harness throughout.
http://www.geocities.com/skyjet1/DRL.html
