Turn signals and hazard lights not working
scout, when the short ocurred did it blow a fuse? im dealing with the same circuit but it repeatedly blows the#2 fuse. and funnily enough i did move the steering wheel up on friday. too weird, but i dont want to have to keep my wheel in one position, so we shall check it out in the am.
on
Remove the knee panel, and make sure the MFS connector is together.
Some have had the truck's side of the harness get pulled tight, and it starts to pull the connector apart.
Pull up some slack on the truck side of the harness, and zip tie it to the knee panel frame.
Take the connector apart and make sure none of the pins are discolored or damaged. If you can get it to plug back together, and hold you are good to go. If it moves you will need to zip tie the connector together
The turn signals and hazaard lights on my 2006 F150 just stopped working all of a sudden. I've checked all of the fuses and they're fine. All I've checked are fuses. Are there relays that should be checked? Should I check the multi-function switch? Is it possible that the switch could be stuck and not bad? Thanks for any help you can give. It's driving me crazy.
