another led problem thread..sorry
ok,i have a 2004 screw..installed 3rd brake light led..no problems..installed front blinker leds and got faster blinker{which i could live with} today i installed rear brakes,blinker and reverse leds... blinker made loud noise and just stays on so i got some load resisters from autozone to put on rear lights and it is still doing it....and i noticed my third brake light is half on all the time now{ when key is turned }
i know there was a thread about a blinker box or something that went under steering colum but i cant find thread.. can someone please help me
sorry so long..thanx
i would return the load resistor and put an LED flasher in place of your oem flasher. you wont get the hyperflash anymore. the flasher is a PITA to get to, so turn your signal on when ur in the truck so you can hear for it and see it.
It's called an electronic flasher, if he has no idea what that is then he's an idiot. Get the electronic flasher EP27, cost me about 15 bucks from auto zone. That will solve the fast blinker issues but not the third brake light staying on. I've heard of guys solving that problem by using a load resistor in the third brake light. Not sure of any other fixes tho.
got a new flasher and that fixed the blinker problem but my 3rd brake light is still staying half way lit all the time... when u hit brakes it lights up fine ..4 out of the 8 leds stay lit up when ignition is on... what can i do? there is no room to put a resister on 3rd light.. can i change fuse?
got it fixed.. i am a idiot... i wasnt crimping the wires hard enough on the resistor...had to just put on one resistor on driver side tailight...
- Jack
just listened for it when blinker on and wasnt hard to find but was a **** to get out...only took about 15 mins though... mine was a little blue box under steering colum..
