left brake light?????
Old Apr 13, 2009 | 12:11 AM
92yj's Avatar
my left brake light comes off and on. i took out the bulb its good, looked at all the wires. they are all good. it was funny i was messing with the signal lever an every time i stepped on the brk and moved the lever up and down the light would work. any ideas. could it be the switch, relay,or something else?
Old Apr 13, 2009 | 07:07 AM
projectSHO89's Avatar
You need to identify your truck.
Want to guess how many year's worth of F150s are out there and how many different versions of the stop lamp circuit there are?
Old Apr 13, 2009 | 09:09 PM
92yj's Avatar
oops sorry, it is a 1997 f150 4.6 xlt. it has a tilt wheel. do you need any Moore info
Old Apr 14, 2009 | 01:37 AM
masseyman's Avatar
I would try a different new bulb anyway on the left side, or switch the left and right bulbs.
Old Apr 14, 2009 | 09:43 AM
SSCULLY's Avatar
The bulb works when you move the turn signal up and down, or the steering wheel column ?
Try a quick test ( aside from the one in masseyman's post ).
Turn the hazards on.
Put the steering wheel column all the way down <- Check both tail lamps
Put the steering wheel column all the way up <- Check both tail lamps
If the light starts to work by moving the steering wheel column, then the connector would be an issue ( pulling apart ).
Old Apr 14, 2009 | 08:20 PM
92yj's Avatar
well i pulled the multifunction switch out and cleaned the contacts, also pulled it apart and cleaned the contacts. wow it works, it is working good now thanks guys for all of the help.
Old Apr 14, 2009 | 09:12 PM
SSCULLY's Avatar
None of us helped with that, hadn't gotten that far.
Great work with the search though !!
