Power Door Lock Doesn't unlock
Old Feb 27, 2009 | 01:08 AM
Rainforestrider's Avatar
When I press the drivers switch to unlock all 4 doors the rear drivers side lock only comes up part way and does not unlock completely. The lock mode works fine.
Any ideas?
Old Mar 3, 2009 | 05:11 AM
solutions's Avatar
solenoids are usual suspects but you may want to remove & inspect the latch assembly carefully. i've found some in the past that have an issue allowing one direction to work fine and not the other. a small broken spring would fall out if shaken. wish i could tell ya an easier way to check it but cant think of any.
Old Mar 3, 2009 | 07:24 AM
cH1rO420's Avatar
Try using the search function or google it. You may find the a similar thread and then it'll lead you to other f150net site which has the write up on how to fix sluggish doors.
Old Mar 6, 2009 | 08:06 PM
I will check the latch assembly first as the lock comes up part way but not enough to unlock it. It works about 30% of the time so maybe it's a weak spring.
