Fog Light Problem
Sadly I am the farthest thing from being a good mechanic or electrician so i figured i would ask on here. I have an 05 ford f150 xlt with a 5.4 and i am having a problem with the passenger side fog light as well as the passenger side license plate light. I think it is just a fuse but have no idea as to which one it could be. I swear i pulled out all of them and they were ok, (i will admit that after my fat *** was in the awkward position i was grabing fuses i could have overlooked some.) I know it isn't the bulbs because i checked those. Any help would be grand.
It sounds like they are out, but you never said.
Fuse for the fog lamps is common to left and right, so if the left is working, it is not a fuse.
Try taking out the problem side, and sticking a meter on the 2 pins on the bulb connector. If you do not have a meter, you can swap the bulbs ( left <-> Right ) and see if the problem follows the bulb. Remember not to touch the glass on the bulb.
The license plate lamp ( if out ) same thing, Meter (or swap ) them. That is on the fuse with your parking lamps, so probably not the fuse.
If you do not have an owners manual, you can download a pdf version here
https://www.fleet.ford.com/maintenan...ls/default.asp
[QUOTE=SSCULLY;3604652]What is the problem ?
Yes they are out. an sadly i already tried switching the bulbs and that isnt it either. still at a loss...
