1998 PCM Connector picture
Could someone please post a picture (or contact me to send an email) of the PCM connector from the Ford Electrical Manual for a 1998 f150 w/ 4.6L. At the end of section 24, there should be an image of the PCM connector with pin numbers and locations. Below the image is a chart showing what each pin is for. It may be 2 or 3 pages.
I have a 1997 truck w/a 4.6L, but my wiring/pcm pinout does NOT match what is in the 1997 Ford Electrical manual. I'm guessing it may be a "later in the year" model and match the 1998.
Thanks!
Thanks!
on
The DVD is not a pdf version of the paper, does not work that way.
When I select show connector C174 from cell 24, that is the only image that shows, the remainder of the pins are not in the JPEG.
What are you looking for on the PCM ?
That might be able to get the info you need ( pin & color code ) from the specific cell.
on
on
I had to resort to my 1997 paper manuals because the 97 CD is corrupt and I cannot find the replacement files. The only reason that I remembered the build date differences on the 97 is that I had the manuals a few months before the truck was delivered. I used to sleep with them.....
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
