Climate control cluster doesn't light
Old Jan 20, 2009 | 10:01 AM
2003_FX4's Avatar
The light for the 3 control ***** for the climate control (beneath the radio)no longer lights when the running/headlights are turned on. All opther lights work fine. It appears to be a blown bulb(s). How do I get to the bulb(s) to replace it? The truck is a 2003 SCREW FX4.
Old Jan 20, 2009 | 11:14 AM
SSCULLY's Avatar
there are bulbs behind the HVAC controls.
I think the process was remove the oval surround around the radio ( including the HVAC vents ) , then the screws around the HVAC controls are visible.
There are a few spring clips that hold it on. You can use a trim puller, or reach in the HVAC vents, and give a good pull out.
