Auto On headlights stop working.
Old May 30, 2008 | 10:34 PM
mjt123's Avatar
I just installed HID kit and now my headlights will not come on automatically at night. Is there a fix. Thx Mike
Old May 30, 2008 | 11:30 PM
NoLongerJeepin's Avatar
Have you tried using the search feature?
Old May 31, 2008 | 02:32 AM
warrantyvoider's Avatar
good luck
Normal Operation
With the headlamp switch turned to the AUTOLAMP position, a battery voltage signal is sent to the vehicle security module (VSM) through circuit 220 (VT/OG). The VSM then determines the amount of ambient light based on the input received from the light sensor. The input signal from the light sensor to the VSM is received through circuit 218 (WH/VT). When the ambient level has reached a point (determined by the internal programming of the VSM), 2 internal relays are energized to supply voltage to the exterior lamps. Circuit 196 (DB/OG) supplies voltage to the internal headlamp relay, which then supplies voltage to circuit 15 (RD/YE) when energized. Circuit 195 (TN/WH) supplies voltage to an internal parking lamp relay, which then supplies voltage to circuit 14 (BN) when energized.
DTC B1793 — sets when the VSM detects a short to ground on the autolamp sensor input circuit.
Possible Causes
Circuit 218 (WH/VT) short to ground
Circuit 220 (VT/OG) open
Light sensor
Headlamp switch
VSM
Old May 31, 2008 | 08:20 AM
mjt123's Avatar
Were would the light senor be on a 2006 Larait. Is it on the rear view mirror ?
Thanks Mike
Old May 31, 2008 | 08:27 AM
Screw-Me-05's Avatar
Thanks Mike
It's on the dash in front of the steering wheel(left of the wheel) lil black dome with the red LED light
Old Jun 2, 2008 | 02:54 AM
what exactly did you touch and wire into when installing the HIDs and i will try to narrow it down for you
