Cruise Control will not engage?
I have a 02 F-150 crew cab 4X4 w/about 52k and the cruise control will not engage. I checked all the fuses(in cab and underhood)and they looked to be fine. Any comments or suggestions???
Thanks! |
Mine didn't work all the time only intermently as well as the horn, It ended up being the clock spring. Take the steering wheel cover off and look to see if any of the wires are loose. Also, if you have a haynes book see if you can trace down wires back to the cruise control.
Crusie Control will not engage
Thanks for the info. Will do!!
Far, far more common failure is the deactivator switch on the master cylinder.
If the recall has been performed, include the fused link in the add-on harness. Steve |
Try this
https://www.f150online.com/forums/sh...trol+self+test :thumbsup: got me fixed mine was a bad servo if you pedal dosent move then it my be the servo |
