will this instrument panel work ??
Old Nov 26, 2007 | 10:31 AM
heatin97f150's Avatar
Arrow will this instrument panel work ??
ive got a 1997 f150 4x4 w/o tach and my odometer quit working and half of the lights are burnt out. i was wonder will a instrument panel out of a 1999 f150 work?? I've found two different 1's one has a tach and the other dosent but it looks like the odometer reading is digital is this correct?? and will it work in my truck since mine isnt digital???? any help please im lost on this 1 and want to be sure b4 i order anything
THANKS
Old Nov 27, 2007 | 12:46 AM
minimonster17's Avatar
It WILL "work," but the digital odometer will have to be programmed by a dealership in order to display your truck's mileage. you may also have to add some more harnesses in to accomodate the new cluster assbly in your truck, not too sure there... the harnesses may or may not already be in there. if not, then they would have to be added as well. good luck!
Old Nov 27, 2007 | 12:58 AM
Zaairman's Avatar
Won't work. The digital dash doesn't remember mileage like your analog dash does, it is simply a display for the mileage, kind of like a calculator screen. It doesn't do any work at all, but it does show you the numbers. Bulbs are easily replaceable, so I wouldn't worry about that. I have no idea what is causing your odometer problem, however if you find an analog dash with a tach, it will plug right in.
