F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Electrical Systems (https://www.f150online.com/forums/electrical-systems-67/)
-   -   '97 F150 4x4 won't start (https://www.f150online.com/forums/electrical-systems/264593-97-f150-4x4-wont-start.html)
cduarte Dec 14, 2006 05:53 AM
the truck ran fine yesterday, now when I turn the key everything goes off and the "battery saver" relay starts clicking. I haven't put a multimeter on the battery yet, but will as soon as it's light out. The truck also has the original battery, so it's probably time for a new one. Anything else I should look at? btw, I also replaced the starter and cables last year so they should be fine.
jbrew Dec 14, 2006 06:24 AM
Check the Guiness book - never heard of a battery goin that long without a swap out.
I've heard goin as far as 7 years , but almost 10? You sure it's the original?
If so - get another just like it !! :thumbsup:
cduarte Dec 14, 2006 07:01 AM
yes, it's the original... and i just tested it, and I'm getting 12.4 volts. The battery cable that goes to the starter relay is warm, so I'm thinking the starter is bad. :(
projectSHO89 Dec 14, 2006 07:33 AM
Check the battery voltage with a heavy load on it, such as the headlights, to make certain that the battery isn't failing under load. A voltage above 12.0 V is a sign of a battery that is still good.
However, with a warm starter motor cable, your suspicion of the starter motor is probably correct.
Steve
cduarte Dec 14, 2006 07:16 PM
fixed it, ended up being a loose battery cable, thankfully.
keith97xlt Dec 18, 2006 03:41 PM
are you gonna try to get another 10 years out of that battery??? lol
