F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Electrical Systems (https://www.f150online.com/forums/electrical-systems-67/)
-   -   Key in Ignition bell won't turn off (https://www.f150online.com/forums/electrical-systems/249185-key-ignition-bell-wont-turn-off.html)
jjnunn Aug 4, 2006 08:08 PM
I have a 2006 F150 and when I stop the vehicle and take the key out of the ignition the bell does not go off. It acts as if the key is still in the ignition and is pretty annoying. I unhooked the battery and that did not help. Any ideas. I checked all of my lights and they are all off. It does not seem to be running the battery down, but I do not want to take the chance.
projectSHO89 Aug 4, 2006 09:11 PM
Since it's an 06 it should still be under warranty. Your dealer should handle this.
FWIW, it's a small switch mechanism on the bottom of the steering column, usually. Possibly a GEM module issue.
Steve
carF150 Nov 2, 2006 02:42 PM
Did you figure out the problem or the fix?
My wife's expy has started doing this.
