F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   Electrical Systems (https://www.f150online.com/forums/electrical-systems-67/)
-   -   2001 Ford SCrew Horn Doesn't work (https://www.f150online.com/forums/electrical-systems/176627-2001-ford-screw-horn-doesnt-work.html)
MAXXIS2001SCREW Nov 29, 2004 08:38 PM
Relay under the hood clicks when horn is hit and I have tried another relay in place of. No power to the horns pulled the plug and cannot get any voltage reading. Every once in a while horn will blow really soft for just a second when I double lock off the keypad. Otherwise no sound when I hit the horn or hit the lock or panic button on the remote. What gives and is their another fuse I do not know about or something I am not trying. Super weird for the wire from the relay to the horn to be cold. any help would be appreciated.
JMC Nov 30, 2004 03:03 AM
Have you checked the ground to the horns? Have you checked the cruise control servo connector under the hood. make sure it is pluged in properly.
JMC
MAXXIS2001SCREW Nov 30, 2004 10:55 AM
Thanks for the help
cruise control works fine, but from what i read on here I they are kinda interrelated. That servo is right in front of the fuse box if I am not mistaken? What about the ground wire to the horn any easy way to check that out. Thanks for the help.
