Door Ajar Light won't go off
Old Mar 20, 2003 | 09:28 PM
ldecaria's Avatar
My door ajar light won't go off now. It started having problems a few days ago but went off. Now it won't go off at all and my interior lights won't go out when I shut the truck off. Where is the switch for this. THe problem is definately in the drivers door cause before when it would be tempramental I tried opening the pass side door and the light went off when I shut the door then opened drivers side and it would stay on. Anyways I had to pull the relay for the interior lights now so I won't kill my battery. So if anoyne can help please let me know how to fix this.
Lorenzo
Old Mar 20, 2003 | 09:30 PM
TexfordD's Avatar
spray wd40 into the latch assembly on the end of the door and open and shut the door a couple of times and repeat..P.S. welcome aboard
Old Mar 21, 2003 | 04:20 PM
medic's Avatar
What TexfordD said will do the job. Just don't forget that you have two (or more) doors.
Old Mar 26, 2003 | 01:43 PM
ldecaria's Avatar
Thanks alot everyone that e-mailed me and helped. I just did this last night and today I tested it all out and stuck the bulb back in and the relay. Worked perfectly. It now shuts off like it's supposed to and I have lights inside once again. Thanks alot
Lorenzo
Old Mar 26, 2003 | 09:37 PM
TexfordD's Avatar
Your welcome and again welcome aboard
Old Mar 31, 2003 | 05:49 PM
Macza's Avatar
Smile WD40 works instantly
Thanks for the TIP!!
spraying wd40 into both door latches took the "DOOR AJAR" light OFF! it was stuck "ON" It also took care of my inside light for being ON. Now all works normally. Thanks again for the tip.
MAC.
Old Mar 31, 2003 | 06:20 PM
TexfordD's Avatar
you too are welcome and also welcome aboard Macza ...tell a friend even a stranger about this site..you won't believe how many will tell you they've never heard about it
Old Jan 1, 2005 | 02:42 AM
miked404's Avatar
Wink WD 40 worked for me
Wd 40 worked for my door latches and dome light went right out. Thanks All
Old Jan 1, 2005 | 12:18 PM
lees99f150's Avatar
welcome.
This site will help you fix alot of problems without having to spend a lot of money. The info you will find here is the best you will get.
Old Jan 3, 2005 | 01:04 PM
roger2000's Avatar
Hey,
My door light didn't go off.So like ya'll said I tried the wd-40 and the door ligt has gone off .Now it works fine.Great site.thanks for posting .Happy New Year 05
Old Jan 3, 2005 | 09:31 PM
macojoe's Avatar
I have been having the same problem. But on and off? I thought it had to do with the remote control locks??
I stoped using the remote, and it has seem's to have stoped, but I am not locking the doors eaither??
What is spraying the WD40 doing when it is sprayed on there?
Thanks all!
Old Jan 4, 2005 | 12:10 AM
lees99f150's Avatar
that is where the switch is located that turns the dome light and door ajar light on. WD40 cleans and lubes it.
Old Jan 4, 2005 | 06:55 PM
lvbndad's Avatar
Talking Thanks!
[B][I]
Thank you guys very much! After work today I was going crazy trying to figure out why that darn light, would not go away! Until I found this site!
My problem is now fixed ! I didn`t even have to ask. Thanks again.
Respectfully,
lvbndad (Reggie Sr.)
Old Jan 7, 2005 | 12:39 PM
Karlymac99's Avatar
Cool 1999 door ajar/lights on
I am new to this site, what a great tool!
Thanks! We are having the same problem. Just bought the truck and interior light and cargo light stays on. Mechanic told us that the sensor is only sold by For and costs $265! I think I'll try the WD-40 trick first. Obviously this is a Ford problem with this model and year.
Old Nov 16, 2005 | 09:19 AM
Scott98150's Avatar
Thanks for the help!
I had been struggling off and on with this problem for almost a year. Tried the wd-40 trick and PRESTO! Works like a champ.
You guys rock!
Scott
