what would happen....
Old Oct 31, 2002 | 02:50 PM
V8KILLAH1
Guest
Posts: n/a
What would happen if I installed a chip that was originally programmed for big mods like gears, superchargers, NOS, etc...but my truck was stock?
Old Oct 31, 2002 | 03:14 PM
Zyg's Avatar
Zyg
since a supercharger and nos basically get more air into the engine you would likely run real rich. The gear changes in chip would likely cause problems with your shift points etc. I dont think it would hurt anything but it likely would not give you any benefit. Mike will im sure shoot you the exact details.
Old Oct 31, 2002 | 10:43 PM
Former Sponsor
Hi V8,
Well, that would really depend on just exactly what the chip in question really was programmed for, assuming that it's a chip that even has your computer code to begin with.
For example, if it was a supercharger only, then you'd be running pig-rich A/F's & not enough timing trying to run that kind of program on a stock truck, so you'd be way down on power & the mpg would be poor.
If it was programmed for different gears, then your speedometer would be off, as well as the odometer and the shift poings in an automatic transmission. You could also have the top speed limiter kick in way too early.
If the chip was programmed for nitrous, then once again, on a stock truck you'd be running pig-rich A/F's, not enough timing, and be way down on power.
The bottom line is, you *cannot* do that, my friend. If you come across a bargain on a chip like that, you will have to have it reprogrammed *properly* for your vehicle before you can use it.
Old Nov 1, 2002 | 01:55 PM
V8KILLAH1
Guest
Posts: n/a
Thanks guys, I just wanted to get educated real quick with the facts. I really wouldn't have installed it, and nor would I ever buy a used chip!
Brand spanking new, made for my truck is the way I am gonna go. Mike, with just intake and exhaust, do you do a special program for just those two mods?
Old Nov 1, 2002 | 03:40 PM
Zyg's Avatar
Zyg
Nothing wrong with a used chip as long as it will work for your computer, just make sure it contains the proper code for your truck and if not Mike can always reprogram it for you.
Old Nov 2, 2002 | 01:04 PM
Former Sponsor
Hi V8,
Whether you even need any different tuning depends on just exactly what you do to the intake & exhaust. The typical intake kit & cat-back exhaust system, which is I think what you mean, will be fine. They don't need any tuning compensations beyond what we're already doing, there's enough fuel in the program @ WOT for an open intake & exhaust already.
If you were to do things like change the MAF (mass airflow meter), or headers, then yes, those would require custom tuning to compensate for.
