Schip/flip chip
Hi
Need clarification.
My flipchip...87/91+oct. Currently using 91oct. Thats the highest (pump) here.
Going on trip...I may be able to get 92/94oct.
Going from 91 to 92/94...do i do nothing..and advantage of higher oct. comes in with mileage?
Or would it be better to clear the PCM to allow the 92/94 to kick in sooner? Not forgetting the differences in octane..diluting or mixing 91 with 92/94 or vice versa with whats already in tank.
Ideally...highest oct. all the time...but depending on where your traveling..might not be able to do that.
My truck...25gal. tank.
Thanks....OT
Need clarification.
Thanks....OT
Hi OT,
I wouldn't mess with clearing the PCM just because you'll be getting a chance to use a little bit more than 91 octane, even if you run into Sunoco's Ultra 94 octane, I would just fill 'er up as usual & keep driving, leave the PCM alone.
If you're going for all-out power at the drag strip, and don't mind going back thru the relearn cycle & starting the adaptive strategy adjustments from scratch, sure, you can clear the PCM after tanking up with 94 octane & see what happens. But unless you're looking for every last bit of ET at the strip, I would leave it alone & just drive the vehicle, using whatever premium gas of good quality you find along the way, from 91-94 octane, and not give it a thought.
Good luck!
Good luck!
