Found gryphon
Old Jan 4, 2013 | 07:21 PM
rexshiver's Avatar
Found gryphon
Found a used gryphon for sale and the man says its ready to plug and go. He said he rturned his truck back to stock and it has the tunes:tranny only, 87 towing, and 93 performance. What do I need to look for when I go check it out? How can I tell if it is not locked to his truck?
Old Jan 4, 2013 | 08:11 PM
radar's FX4's Avatar
Make sure it works on yours first. You will notice a big difference!
Old Jan 4, 2013 | 08:23 PM
rexshiver's Avatar
Do I have to drive it to tell if it works?
Old Jan 4, 2013 | 08:26 PM
sam1947's Avatar
If it has custom tunes on it chances are it wont work on yours as the PCM HEX code will most likely be different. If they are canned tunes, it should work provided he actually 'un-married' the unit from his truck.
Old Jan 4, 2013 | 08:46 PM
rexshiver's Avatar
He says they are canned. But my question is how will I know if it works or not?
Old Jan 4, 2013 | 08:49 PM
If it recognizes your truck and is ready to load, should be good.
Old Jan 4, 2013 | 09:41 PM
Veteran: Army
so it's an Edge Evo, not a PHP Gryphon
Old Jan 4, 2013 | 09:50 PM
rexshiver's Avatar
He says it a gryphon
Old Jan 4, 2013 | 09:53 PM
either way, once it is loaded you can tell a difference.
Old Jan 4, 2013 | 10:24 PM
rexshiver's Avatar
Which one of those tunes would be best for mpg on the highway?
Old Jan 4, 2013 | 10:27 PM
Veteran: Army
the maintenance and driver mod
Old Jan 5, 2013 | 10:07 AM
dfergus's Avatar
Old Jan 6, 2013 | 05:44 PM
As Tarajerame plainly states, don't buy the programmer expecting a high MPG increase. Buy it for its functions and its convenience as it may never pay for itself with fuel economy savings.
Old Jan 7, 2013 | 11:58 AM
rexshiver's Avatar
And another question can I run this with the gotts mod without any issues?
Old Jan 7, 2013 | 12:04 PM
Yes, not an issue.
I ran the Edge canned tunes for about 31,000 miles nearly all on Level 3 with the shift pressure bumped up, then ordered PHP custom tne. I put about 70,000 on the 2005 with the custom tune. Had about 33,000 on it before I added the Edge. So, with a total of 135,000, 101,000 with a tune, the truck was still going strong when I sold it. Never a problem other than the throttle body had to be cleaned at about 101,000.
