Need to update Gryphon but i have a Mac...
Tried downloading a couple recomended programs so i can set my gyphon back to stock but none of them have worked... Has anyone else had this problem? i would like to call php myself but im always working during their contact hours and can never find time to get ahold of them.. any help would be greatly appreciated, thanks.
You could run a virtual machine and run windows on your Mac. IDK if that's the solution you are looking for though.
You WILL need to use a Windows PC or the Windows virtual machine on a Mac. Surely one of your friends with a PC will let you install the software long enough to do this.
- Jack |
Public libraries usually have windows machines. If I had a mac that is where I'd go.
all my friends have macs, its pretty ridiculous to be honest.. good idea about the library though, might even go hit up the local college since its closer now that i think about it.
You will probably find that a library will have their machines locked down where you can't install software on them.
http://www.parallels.com/Virtual-Windows http://www.vmware.com/products/fusion/overview.html http://www.macupdate.com/app/mac/6078/virtual-pc |
Originally Posted by glc
(Post 4721670)
Normal if your drivers aren't loaded right. Basically the computer doesn't know how to correctly communicate with the device.
Originally Posted by Longshot270
(Post 4722010)
Originally Posted by TPAYNE
(Post 4722046)
oh ok. i just gave up on it and went home. installing parallels on my mac now but its only the 2 week free trial since the real version costs 70 bucks! ridiculous.. hope this works though.
If the driver problem occurs, the only solution is to uninstall Pegasus and then uninstall the drivers. Then, start over. The Gryphon's screen is red when it is not connected to Pegasus (but plugged into the PC). The screen turns green when a connection is established. - Jack |
(Post 4722070)
Do NOT plug the Gryphon into the PC until you have Pegasus installed and running! The Pegasus installation contains the proper drivers for the Gryphon. If you plug the Gryphon into the PC before you have correctly installed Pegasus, it will try to install drivers and will use the wrong ones. Then, the Gryphon will not connect to Pegasus.
