entry code
Old May 12, 2011 | 11:43 AM
karlnord3's Avatar
entry code
I purchased a 2005 lariat recently and was unable to get the keyless entry code...a local dealership wants to charge me over $100.00 bucks to retrieve it..is there any other way to get this factory code???
Old May 12, 2011 | 12:01 PM
Norm's Avatar
On label on module behind the seat for 2005 if I remember correctly. There was a thread on here about it. Use the search tool above.
Old May 12, 2011 | 12:36 PM
JackandJanet's Avatar
Here's a link to the rear seat removal process: https://www.f150online.com/forums/ar...08-my-way.html
Yes, the code is on a computer module behind the seat back.
- Jack
Old May 12, 2011 | 12:38 PM
If it's a supercrew, yes, behind the back of the rear seat. Or there may be a card in in your manual, if the dealer did not remove it. It takes the dealer about 5 minutes to hook up a computer and retrieve the code. They should do it for free.
Old May 12, 2011 | 01:30 PM
karlnord3's Avatar
thanks for the info.....the clown at the dealership would have charged me 100 bucks,.....
Old May 12, 2011 | 01:46 PM
Justin_w32's Avatar
Dealer wanted to charge me $75, I said no thanks I'll just get it off the module behind the seat, they just looked at me like how do you know that? I told them it was a rip off and walked out.
Old May 12, 2011 | 06:14 PM
Drewcifer1806's Avatar
is it also behind seat for an extended cab, not screw?
Old May 13, 2011 | 06:34 AM
Norm's Avatar
Yes
Old May 13, 2011 | 11:14 PM
Strokeer's Avatar
Remove the small storage compartment in the dash (one right of the steering wheel about knee high, Little mini glove box compartment? Squeeze tabs and it should pull out and hang freely.) push the white insulation out the way and there you will find the module, You should see the sticker on the module with a 5 digit code.
Worked for me, 2005 Ford F-250 Lariat Fx4.
Old May 14, 2011 | 03:14 AM
i dont believe the lariat has that. all it has is that small ash tray
Old May 16, 2011 | 11:33 AM
Strokeer's Avatar
I have a lariat and it does.
Old May 16, 2011 | 01:49 PM
2007 Loaded FX4's Avatar
Does anyone know where the code is on a 2011 FX4 Supercrew?
Old May 16, 2011 | 02:17 PM
malexander52's Avatar
ditto
My 2007 only has the ashtray to the right of the steering wheel and the change holder on the dash itself.
Old May 16, 2011 | 06:52 PM
Strokeer has an F-250. The "back seat" solution is for F150s.
- Jack
