Gryphon error.. Please help!!
Old Mar 17, 2011 | 07:55 PM
kobra_commader's Avatar
i got a new to me Gryphon from another member here...well i got to put it in the truck this afternoon and everything was workin good and i went to put the level 2 canned towing tune in and it gave me the following code ( checksum failed RXAP9B6 )
whats happening?
after i turn the ign back off and unplug it and turn the ign on and plug it in it works and the truck starts and runs like its supposed to..
thanks
Troy
the truck is an 04 f150 lariat 5.4 4x4 with cold air and magnaflow cat back.
Old Mar 17, 2011 | 07:58 PM
svt2205's Avatar
Troy, I posted over on the PHP site hoping that we can find a solution to this.
When you plugged the unit in did it read the hex code and run you thru 1 or 2 disclaimer screens?
Old Mar 17, 2011 | 08:05 PM
yes it did.. my hex code is this RXAP9B6.hex
i just noticed that the fail code and hex r the same
Old Mar 17, 2011 | 08:17 PM
svt2205's Avatar
If you can't resolve this problem, I'll make things good with this deal.
Old Mar 17, 2011 | 09:36 PM
whats happening?
thanks
Troy
Sometimes during the FIRST programming session its a good idea NOT to open custom options to change gear ratios or tire sizes.....that's what its sounds like happened...the other thing is you might want to check your battery...clean your tb....clean your maf.....
Old Mar 17, 2011 | 09:57 PM
i think u miss understood me.. i didnt go into the custon setting all i wanted to do was to put the level 2 canned tune into use and it was doing its thing and that fail message came up... the truck is new to me and i do not no much history on it
the battery is fine as i drive the truck daily... the tb and maf could probly use a cleaning but i cant see on how that made it trip that code
Old Mar 17, 2011 | 11:25 PM
My crystal ball is broke and that's one thing you should have addressed when you started your first post....btw you forgot your engine size.....
And as far as your battery goes.....Haha....you've got to know the battery manufactures these days.....most of the batteries on the market can give out at any time without warning.....don't assume your battery is fine cause you drive it everyday....programming sessions can cause marginal batteries to show their true colors....
Read the stickys at the top of the forum.....especially the ones involving the Gryphon...
Old Mar 17, 2011 | 11:57 PM
"the truck is an 04 f150 lariat 5.4 4x4 with cold air and magnaflow cat back."
i said it was a 5.4
what should i do to the batt? have it stress tested? it was starten fast and quick when we were haven 0 degree days so i dont think the batt is the problem.
and what are you being a smart *** for? im just looken for some help.
Old Mar 17, 2011 | 11:59 PM
and where did i say i was messing with the custom settings?
Old Mar 18, 2011 | 04:20 AM
svt2205's Avatar
He's just pointing out that in the first tuning session it's sometimes a good idea to just go with the canned tune before taking the next step and screwing around with things.
Hey, 88racing is thinking a little further outside the box that you or I are considering. He knows far more about these things and can offer up possible solutions to this problem and others.
Old Mar 18, 2011 | 06:36 AM
DarkShadowSTX's Avatar
Yes he does.
Did you have any electronics on during the tune change? I've heard that if you have a simple thing on like the dome light, that the programmer won't get the full amount of battery to carry through with the tune change. I always sit in my truck with the door closed, all lights off, radio off, fan off and just don't touch anything until the tune is done just to make sure.
Old Mar 18, 2011 | 09:53 AM
Originally Posted by DarkShadowSTX
Yes he does.
i was in the truck radio off and im pretty sure my headlights were off...but i still think that the previous owner musta had something on it b4 i got it..
im ganna call php today and see what bill says
thanks for the tips guys
Old Mar 18, 2011 | 12:51 PM
JackandJanet's Avatar
I doubt that, kobra - It also looks to me like the previous owner is talking to you in this thread and seems more than willing to help you resolve the issue.
Now, it is quite possible that a file in the programmer is corrupt. You may be able to correct the problem if you download and install Pegasus from PHP's website. Once you have Pegasus running on your PC, plug the Gryphon in. Pegasus should recognize the Gryphon and report that it is "connected". The Gryphon's screen should change from red to green.
Then, select [Updates]->[Gryphon Update Manager]. If Pegasus detects anything amiss with the Gryphon, it will probably show you firmware and calibration updates you can apply. If it does, apply them. Then, try the Gryphon in your truck again.
If it still doesn't work, you'll have to talk to Bill.
- Jack
Old Mar 18, 2011 | 12:59 PM
- Jack
i got it all down loaded and it did say i had a flim ware update but wasnt sure if i should go ahead and do it (i didnt wanna mess anything up)
i called php today and talked to Cody and he told me to email Bill
well im ganna try to update this thing and ill give it another go round
THANK YOU!
Old Mar 18, 2011 | 01:31 PM
ok well i tryed to update it and it did (firmware and calibration updates same time)
i was promted to unplug it and plug it back in.. and i did
when i pluged it back in i got a warning that said "device must be restarted...unable to locate valid calibration hex info..
then it tells me to reboot it by unpluging it and pressing menu and pluggin back in
i did this and it did reboot and went to the warning screen
then it tells me to unplug it and plug it back in and to press ok to restart the update process... but when i press ok after doin so it says the gryphon is not found (and the gryphon screen is green)
wtf did i do?!
