Select pids in tree view??????????
Hi I recently got my Predator tuner, and found Ford communicates the knock sensor in volts instead of degrees of timing retard. I did some research and downloaded FordPidDataViewer, or CMR_DAT. When I attempt to start streaming I get a message saying select pids in tree view..the version I'm using is 2.3, is this the most current? I would like to use that program because I think it would convert the knock sensor voltage reading to degrees of timing, is this correct? The Predator owner's manual is laughable, and when I call customer service they love to say "check the website"..do the other programmers also have useless instructions????????
You're correct about the knock sensors transmitting voltage, but I don't know that this value equates to timing retard. I suspect a voltage indicating "knock" simply tells the PCM to retard timing, which it does, aggressively, according to Bill Cohron at PHP. There is then a Spark Advance PID which you could also monitor to see the effect.
However, your questions regarding data streaming and interpretation are specific to the Diablo product and I don't know anything about it. Diablo Mike used to post here a lot and might have some answers for you, if you were to PM him.
- Jack
- Jack
Hi.
Well of course the knock sensors just output a voltage - it's up to the PCM and the calibration running to apply the translation from that voltage to a specific advance value at any given moment, for that specific truck and the exact operting conditions at the time.
As suggested - and this is for learning purposes only - select and log knock sensor voltage, IAT, Load and advance. You'll start to see the correlation. It's not complete without A/F's and some other Pid's but it'a a start.
As for what other tuners can do - and the amount of support for end-user tuning provided - have a look here: http://www.sctflash.com/support/inde...8&pcid=0&nav=0
Specifically - Run the LiveLink demo - you'll be amazed. And this is an OLD version - the new one is even better. It shows the PID tree in detail.
I'm not sure if a Predator prvides passthrough to a laptop or not - if not and you can only log on the device, rmember that there are severe memory limitations so you can only choose a few PID's and capture for a short period of time. I believe this applies to Edge products as well. With SCT, using a laptop/passthrough connection, you can basically select 15+ PID's DMR's, and just drive around - only limit is the drive capacity on the laptop.
Are you perhaps starting to wonder if you picked the right programmer?
For the End-user, SCT has a lock on ease of use, number of tuning dealers, toolset, and support.
MY advice - sell the Diablo and buy an SCT X3 custom tuned by VMP.
Good luck.
MGD
Good luck.
MGD
Hi.
Good luck.
MGD
Good luck.
MGD
Lol I was wondering about that, I didn't want to put it in there and have it get stuck..I'll give it a try.
