predator questions?
Old Oct 18, 2010 | 05:58 PM
99rckstrexpy's Avatar
predator questions?
i have a u7153 diablo predator and when i put the 93 tune on my 5.4 awd expedition and floor it from a dead stop itll go then it kind of sputters then it clears up in the high rpm,and if im rolling along and floor it, its fine, it only does it if i floor it from a dead stop. id say from about 2000 to 3200 rpm, and it does NOT do this when the vehicle is not tuned, idk what it could be and any help would be appreciated, i would like to leave the vehicle tuned but im kind of concerned it could hurt the motor
Old Oct 18, 2010 | 08:08 PM
anybody have anything? i was thinking plugs but i dont know why it would only do it from a dead stop and when its tuned
Old Oct 18, 2010 | 09:45 PM
Does it happen when it programmed to stock?
Have you been performing the mileage maintenance tasks?
Like the fuel filter.
Cleaning the TB.
I was hoping DiabloMike would chime in......
Old Oct 18, 2010 | 09:58 PM
yes ive been keeping up on the maintenece and no it doesnt do this when its tuned to stock. and the fuel filter isnt even a month old. but i havent cleaned the throttle body in a while
Old Oct 18, 2010 | 10:27 PM
Have you tried using the programmer to retrieve any dtc codes?
Spitting and sputtering could be anything from fuel delivery to spark control.........
Old Oct 19, 2010 | 10:32 AM
DiabloMike's Avatar
Former Sponsor
Yeah, thats curious.
First thing Id like to know is what is the revision on the Predator?
Also, are you running premium fuel with the 93 tune?
Old Oct 19, 2010 | 03:42 PM
it has no dtcs and its the lastest revision but im not completley positive on the gas because i was not the last person to put gas in it, i hope thats what it is though, will that cause it to act this way?
Old Oct 19, 2010 | 03:56 PM
If you are running a 93 tune on 87 octane, you should be getting some serious pinging, which is a no-no.
Old Oct 19, 2010 | 03:59 PM
DiabloMike's Avatar
Former Sponsor
Yeah, it kinda sounds like it is getting some heavy KR.
Try loading the 87 octane tune as a quick fix
Old Oct 19, 2010 | 04:00 PM
yea its pinging but its not pinging until it gets to about 4500 rpm when its floored and plus it pings on 87 without the programmer on it and its bone stock other than si/do flomaster. actually i wouldnt be scared to say it pings worse on 87 without the tune than it does with it.
Old Oct 19, 2010 | 04:02 PM
by loading the 87 tune do you mean pull 4 degrees from the wot spark? because it only has one setting.
Old Oct 19, 2010 | 04:47 PM
DiabloMike's Avatar
Former Sponsor
Ahh...yeah, try pulling a few degrees then.
If it runs that bad on 87 with the stock tune, IMO it needs a tune up for sure.
Plugs, and wires for starters, then if it still needs help, look into the coil packs, fuel filter, etc.
Old Oct 19, 2010 | 04:59 PM
okay thanks for all the help guys
Old Oct 19, 2010 | 06:55 PM
JimmysotherFORD's Avatar
start with the fuel filter, it's the cheapest thing to replace. then look into plugs.
Old Oct 19, 2010 | 07:03 PM
my fuel filter is brand new. i sure hope it doesnt need coils. its not like its skipping bad but it only does it when its tuned and from about 2k to 3k when its at wot its like it stumbles then clears up and goes fine. but imma pull some timing from the programmer and see if that helps and if not guess ill change the plugs
