Evolution help
Evolution help
Why is it when I go into customize the towing performance to change the tire setting when I turn the key off it goes back to 2356 every flippin time whats wrong with this thing.. If anyone can walk me through it it would be helpful I need to change the mm to 2660. Thanks
It really doesn't change, but when you open the Custom Options menu, you get a "Placeholder value" for TS and GR. The TS is usually not right, but the GR may be. If you want to see the value you entered before, ALWAYS scroll immediately to "Load Previous Settings" BEFORE you go anywhere else after opening that menu. (Note, the value will probably still be slightly different due to internal calculation rounding).
As 88racing said though, set your TS to 2660 and make sure your GR is correct, then scroll to "done" and when your PCM programs, forget it.
- Jack
- Jack
And, Bluejay's question about GR needs to be answered too.
- Jack
All I was trying to do was just change my tire size to get the correct speed so I set it at towing then i went in to custom it and put my tires size in so my speedo would be correct then I tired to save and get out. my tires size is 325/05/18 the catalog says to use 2660 so I dont think that is incorrect
Whats the default in the edge mean. I dont know what gears are in my truck I bought it used but Im assuming 3:73. Thanks
The default is what shows up on the Edge screen before you change the settting. When you go to the gear screen, it will come up with a number that the Edge thinks you have. Probably 3.55 or 3.73. If it is different from what you actually have, then you must change it. You can see what your truck had origianally by checking the tag on the driver'd door, under axle. There will be a 2 digit number like 19 or B9. See what that says. Of course, it is possible that your gears have been swapped if you don't know thw history of the truck.
Ok, a B6 is a 3.73 LS. If the gears have never been changed, that is what needs to be entered in the gear setting if it is not defaulting to that.
F-150:
19 – 3.55 Non-LS
18 – 3.08 Non-LS
H9 – 3.55 LS
B6 – 3.73 LS
19 – 3.55 Non-LS
18 – 3.08 Non-LS
H9 – 3.55 LS
B6 – 3.73 LS
