Custom tunes ordered
Custom tunes installed
just put my order in for tunes through vmp. hope this gets rid of the trans issues and gets me some more power
You will not believe the difference - especially in throttle response.
You needed to ask Justin about the TCM programming portion of your SCT tuning to ease the minds of certain nail-biting, hand-wringing wild-eyed diaper-fillers on here
MGD
- Jack
you are correct jackandjanet i emailed justin before hand to make sure he can program the tcm and he said yes
you'll notice when your installing your tune that the xcal will show pcm and tcm programming on the screen
got my tunes today im impressed but not so much as with my 06 with custom tunes from same place vmp. i talked to justin today and was told that there wont as big of a difference as i got from my 06 with my 2010. i did notice the throttle lag is gone and the trans shifts alot better 1-2 5k 2-3 5500 3-4 5500, dont know about the rest as im already going over speed limit at this point. im gona ask to have the 1-2 at 5350 as the stock shifts at 5500 1-2. justin told me the reason for the difference from 06-2010 is that ford programms these alittle better not as much left on the table as 06. also i dont have a cai on the 10 as i did on the 06 only gotts and cat back exhaust on 10. after reading what superchips posted today about the gains on the 10 with cai that may be only difference 5-10 peak hp and 20-30 ft/lb torque i think would make a difference. dont know if ill get the intake or not also justin told me to run 89 octane to get alittle more out of program as the pcm can detect the difference and adjust. i also tried to take 1 degree of timing out across the board after i filled up with 89 and it stated program failed. i guess i cant change anything and there is no trans shift point or pressure adjustments either. one other thing during the programm it did do the trans seperate from the engine so i know it is getting programmed as well
