Tune Chip
Old Jun 8, 2010 | 10:36 AM
m4rx's Avatar
Tune Chip
Hello there.
I am wondering if the 1998 F150 has a chip in it, and if so, then where would it be located at?
Thank you,
Tyler
Old Jun 8, 2010 | 03:50 PM
DiabloMike's Avatar
Former Sponsor
There is no chip from the factory, but there is a open port in the side of the PCM where you can place an aftermarket chip (known as the j-port).
If there is a chip on the PCM, it is relatively visible as they usually stick out of the box a bit, although some do fit inside under the factory plastic oval shaped cover.
