MPG with Edge Evo?
I drive my truck 60 miles a day to work and back on the freeway i get around 18.5 mpg and when in the city about 16.5 mpg these numbers are not off of the edge i calculate mpg off mileage and gallons to fill it but the edge is really close when i read what it says im getting. I have LT245/75r17 just a little bigger than stock and run them at 50 psi. I also have a full K&N cold air intake and SLP performance exhaust and usually drive my truck in towing level 2 with the edge evolution. Oh and Also i have the stock 3.73 gearing in my truck. Hope that helps
Hello!
Welcome to Ford Truck Owners that Failed Mind Reading. Unfortunately the number you called might or might not be in service. While we make every attempt to provide sound advice, we ain't worth a damn at reading minds (hell we're lucky if we can spel gud).
To assist us in forwarding your call to the correct department please provide the following tidbits of data:
Model year
Engine
Drivetrain
Tire size
Exhaust mod?
Intake mod?
Any suspension mods?
Cab size?
Bed size?
Mileage
Is 12 calculated or computer?
Mainly highway or city? Mix? What % of each?
Last tune up
Last maintenance and date?
Hopefully while you're waiting for your call to be forwarded to our experts, you will take the opportunity to use the AMAZING INFORMATION FINDER. It's guaranteed and best of all IT'S FREE! WOOT!
Model year
Engine
Drivetrain
Tire size
Exhaust mod?
Intake mod?
Cab size?
Bed size?
Mileage
Last tune up
Hello!
Model year
Engine
Drivetrain
Tire size
Exhaust mod?
Intake mod?
Cab size?
Bed size?
Mileage
Last tune up
Model year
Engine
Drivetrain
Tire size
Exhaust mod?
Intake mod?
Cab size?
Bed size?
Mileage
Last tune up
MGD v5.0
just canned tunes haven't done the Gryphon upgrade yet gonna wait till i do headers and high flow cats. Theirs no need to upgrade till then in my opinion I've had my truck dyno tested to check for lean conditions and not once did it run lean in any parts of the test but i will for sure upgrade when i finish my exhaust because that will cause a lean condition at that point.
according to my edge w/level 2 tow setting, im averaging 13.5-14.5 in the city, depending on traffic, etc...
i have an 07 screw, 6.5 bed, leveled, on 35 Xtreme MT's, 17x9 wheels, 3.55 stock gears. i have what you might call a "spirited" driving style, but i dont speed much. i also keep her clean and waxed reel gud, so that helps aerodynamics a whole lot
For the last 2400 miles, I've kept a spreadsheet record of mileage. I get a cumulative average of 15.0 mpg. This is mostly highway driving at 75 mph and about half of it had four adults in the cab and quite a bit of baggage/food in the back. It's using my custom non-tow program and the odometer is accurate.
As you can see from my sig, I have a cap that adds a lot of weight and some wind resistance, since it is about 6 in higher than the cab.
Before I got my programmer, my mileage was close to 2 mpg less, and the truck was a whole lot less fun to drive.
- Jack
- Jack
