Edge Evo / transmission
Old Mar 21, 2010 | 05:18 PM
mugsaway's Avatar
Even with Roush’s tune in the PCM, and some firmness added after dyno sessions, this power level was just too much for the stock 4R75E transmission (note that the 4R75E shares many characteristics with the 4R70E used in earlier F-150s and 4R70W and 4R75W used in other Ford applications). Within 6,000 miles the clutches were slipping badly during the 2-3 upshift and 4-2 downshift under heavy throttle. It was bad enough that the entire cowl would shudder when the transmission was hot."
Don't know what the Roush tune is, but can I assume running the Edge Evo on the tow tune (no customs) is perfectly safe for my transmission? I have the 4R75E transmission. It's tough not knowing what everyone else knows...
Old Mar 21, 2010 | 05:20 PM
Yes, it's safe. It removes a lot of the builtin slippage that wears out the clutches quicker.
Old Mar 22, 2010 | 11:45 AM
JackandJanet's Avatar
And, it fuels the engine slightly richer, to give more power and to keep things cooler under load. (More fuel in a gasser = cooler running.)
- Jack
Old Mar 22, 2010 | 11:54 AM
MGDfan's Avatar
Hello Mr OP!
Not to worry - I don't know nothin' neither .
Except that, the passage you quoted was referring to a Roush Supercharged truck tune - where the tranny is legitimately under much more stress given the potential power levels available at the input shaft.
Not any cause for concern on a stock truck.
Cheers
MGD v4.2
Old Mar 22, 2010 | 03:44 PM
mugsaway's Avatar
The responses are very much appreciated.
